Mercedes E400 Coupe (C238) Cabin Filter Location & Part Number
Ajr3773
Mercedes E Class 400d 4 Matic
Needing to change this due to car being smoked in by previous owner. Am I right to assume it’s located under the glovebox panel?
Also does anyone know the part number or recommend a link to an aftermarket fitment, as having searched online via reg number the sizes appear to differ significantly.
Hello and welcome
Phone Mercedes Grangemouth (Forum sponsor) and they’ll sell you exactly the right filter - mention the forum and you’ll get a decent discount.
mioba
Nottingham and Köln
Go to your dealer and get the right one.
welcome to forum, we look forward to years of contributions!
Gazwould
C250 CDI
But does the dealer sell the best one !
EmilysDad
Bury Lancs
ML350
Needing to change this due to car being smoked in by previous owner. ...
I'm not sure how this will help. The filter is fitted before the smoker .... :confused:
EmilysMum's car was previously owned by a smoker and it did take a while for the smell to go .... she used to put cheap fragrant soaps around the car to help mask the smell.
A
Ajr3773
It’s pointless using any enzyme odour eater without removing one of the main sources of the issue, in that the cabin/pollen filter is is harbouring contaminants from when the vehicle was smoked in.
malcolm E53 AMG
Definitely use the dealer generally they are more competitive than you think, Mercedes Newcastle will post out to you they are on EBay and I use them, alternately MB Grangemouth post out with a forum discount I believe.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Its best to just carry on smoking in the car , but only menthol tabs, lovely and minty after a few lung fulls.
mattkh
England
A160 W168 1999 1.6
The cabin filter only filters air coming in from the outside of the car.
Go for the latest filters, they are only a little more expensive than the normal ones.
Gazwould
C250 CDI
Because they have a biocidal layer plus filter out NOx and diesel particulates !
Why isn't the gubberment telling us about that :rolleyes:
onefortheroad
uk.
Does the air not pass back through it when chosing recirculating air mode ?
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
please post some pics of your car, i have the same model
A
Ajr3773
It was located under the passenger side glovebox. 1 x torx screw and 2 clips but managed to snap the middle leg when pulling out. As someone has mentioned Recirculated air does go through it.
Anyhow after locating I pulled it out, sprayed it with ‘Valet Pro Enzyme Odour Eater’ - Highly recommended and excellent stuff (as well as all other carpeted areas and head lining) Let everything totally dry out overnight, refitted the filter and smell of smoke has totally gone.
onefortheroad
uk.
a2128300318 possibly.
mioba
Nottingham and Köln
Makes no sense at all.
The filter is a replacement item not serviceable. If you had it all open why not put in a new filter as per your original post.
Nows where my bucket of soap and water. I am doing an oil change and Want to wash out my oil filter ;)
onefortheroad
uk.
im changing mine today , ordered a carbon impregnated filter by crossland £19.24 . i tried the pressure washer on my old one , but it didnt end too well :)
mioba
Nottingham and Köln
Why bother with the expense of a crossland.
Some used kitchen roll stuffed in there with a few bbq briquttes for the activated effect is much cheaper
JBell
Torquey
C350 CDi Estate (GAD Edition)
MANN "Frecious" filters are supposed to be the best, just put one in my C, got it from ECP
