Mercedes ML 270 cdi 2002 (W163) - The diesel fuel filter/housing is leaking !!!
13enzy
Rochdale
Mercedes Benz ML 270 cdi Auto W163 2002
Hi
I have a Mercedes ML 270 cdi 2002 (W163) - The diesel fuel filter/housing is leaking from underneath the fuel filter assembly somewhere, but unfortunately i cannot see or locate the actual leaking point, as the EGR unit and the power steering filler reservoir/housing is covering all the area around the fuel filter making it impossible to even see around and underneath the fuel filter...... How can I access the fuel filter housing / assembly area to get a good access to pinpoint the leak and take appropriate steps to fix the fuel leak ???
Do i have to remove the complete EGR unit/housing...and also the power steering filler housing too ???
ajlsl600
france
Try to find WIS on xentry and look up fuel filter housing removal
Where are you? someone can give you local indie contact
Maybe there is a Haynes manual 4 yr car?
onefortheroad
uk.
Is this it ? Probably leaking fuel from the top , the pipes going in/out and fuel heater if fitted . Screenshot_20230424-063640.png
13enzy
13enzy
Rochdale
what is....WIS on xentry ?
13enzy
13enzy
Rochdale
i am in Manchester UK
ajlsl600
france
OK no where near me. Sorryb
onefortheroad
uk.
Computerized images along with a description of what and how to remove and repair , same system that mercedes would use.
13enzy
13enzy
Rochdale
how do i access these images or system
