Mercedes ML 320 benz problem please
miroslavs
New Registration
Hello to everyone,
I would like to ask you something regarding my ML 320 benz V6 2001. You see I have problem with this car.Engine just dies sometime.Sometime when I stop for example for red light the engine dies,sometime I can not even start the car.After a few minutes the car starts normal.I took it to Mercedes service and they could not find the problem.They said that when engine dies it is then that I should bring the car to them.The problem is when I did that two times by the time we got there the car engine started normally.I am getting tiered of this car.So please if any of you had the same problem please write to me.By the way I live in Sweden.
Best regards to you all and hopefully someone will answer.
Hej ! och tjänare :D
This will be the crank shaft sensor that must be replaced.
Vär bör du i Sverige
Blakey
Brighton UK
Is there no end to your skills Malcolm? ;)
