Mercedes ML 320 W163 blend air flap actuator replacement
damianaki
ML 320 W163 1999
Good evening all, I have a problem with my ML 320 W163 of 1999. So no heating in the car and at this very cold time, it is not easy to drive the car without to be sick.
I am aproximatively sure that it should be the terrible blend air flap actuator witch to be breakdown. I find many video on youtube in order to remove and replace but European models with left side steering wheel. Here in Cyprus, because we drive on the left side, my car is right side steering wheel. I am sure that the actuator is not in the same position. Can you advice me if you have this kind of experience and what should be the procedure to remove and reinstall the blend air flap actuator ?
For the European models, It is enought to remove the glove box and the airbag upper the glove box. But for Uk models, I don't know.
Thank you in advance for your help.
