mercedes sl 300 /r129 / 1990
steven petre
mercedes sl 300 /129 /1990
Hi I have a problem with my convertible roof, it won't release or go down, iv had a number of mechanics trying to fix the problem,apparently the roof module is fine so is the hydraulics, i don't whant to go to mercdes with there hourly rate or to sl shop, just need to be steered in the right direction,or is there anyone out there would know a solution.
steven petre
  • #2
Hi I have a problem with my convertible roof, it won't release or go down, iv had a number of mechanics trying to fix the problem,apparently the roof module is fine so is the hydraulics, i don't whant to go to mercdes with there hourly , just need to be steered in the right direction,or is there anyone out there would know a solution.
When you hold the switch in the open position does the light flash in a repeated pattern. Something like 5 flashes, pause, 5 flashes etc? It could be a different number of flashes each time until it repeats i.e 5,6,10,5,6,10 etc.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
I would take it to a good mechanic who knows these cars, not necessarily MB but an MB independent. The roof is a complicated thing.
It will save money in the long term, one diagnostic read out should give you the answer.
steven petre
hi i had a diagnostic done but come back clear.
hi yes the red light does come on, how many repeats do i do?
steven petre
thanks you for your reply
steven petre
Hold the switch in the open position. If the light comes on solid that's no errors. If it flashes count the flashes cycles.
Where in the country are you?
steven petre
iam in surrey heathrow
Wearsafoxhat
Hi, the guy at ACS Autowerks in West Drayton did some work on my R129 and looks after a friends one too.
hi i will put on the switch on tomorrow and let you know, what the out come is, and thanks.
You should hear the pump run when you operate the switch. Do the top rail latches operate? (Usually a loud clunk).
If the pump doesn't run you'll need to find out why - 12v supply, relay, bad motor (assuming the obvious hasn't been missed - no hydraulic oil).
