donaldshorrock
- Oct 23, 2007
Hi, Guy's
I have a Mercedes Sprinter 208D 1996. The problem i have is that the engine runs on after turning off the engine.
I think i have narrowed the problem down to the ignition switch. There is a good vacuum one side of the switch and the otherside has much less suction.
I pulled both rubber pipes from the ignition switch and put them together and the engine imediately stopped with the key in the off position.
Do you think there maybe some kind of blockage from the small distance from the inlet to the outlet side.
Regards Don.
Regards Don.
