AlanDogg
- Nov 21, 2022
- Mercedes Sprinter 313 CDI
Hi Folks, I recently purchased a sprinter 313 (2011) which I purchased to convert into a camper, On removing wall boards I found some horrific after market wiring, I noticed one of the interior courtesy lights was flickering. I gave it a tap and the engine started turning over, along with heaters, wipers, water spray etc all coming on, I quickly removed the light fitting, and it changed nothing, I eventually was able to remove the live from the battery, by that time the SAM module was burnt out. I sourced another module from Holland and fitted it. Everything worked fine apart from the following errors.
1. Side marker lamps.
2. SRS restraint system visit workshop.
3. ESP visit workshop.
4. Rear brake lamp.
I checked the wiring loom that runs from the back of the lights down the passenger side and connects to the SAM module. Removed all tape and found 3 wires melted together. I identified them as rear driver's side brake light (Red/Blk) rear passenger side brake light (Blk/Red) and top rear brake light (Yellow/Blk) I removed these full runs and replaced them and cleared number 4 fault (Rear Brake Lamp)
I checked the rest of this loom and all seems fine.
I'm a bit puzzled to why I'm getting the remaining 3 errors which are not clearing via OBD2. I can only assume, as these faults still exist?
1. Side marker lights
when I switch on the lights the marker lights all briefly flash twice then go through another 4x 10 secs cycle of this then go off completely, I assume there is a short or high resistance level being detected?
2.SRS fault
I did fit a new swivel seat that comes with the connector, but this error was thrown up after the SAM module was blown before the swivel seat was fitted. Tried 10ohm resistor bridging the connector, but it made no difference. ?
3 ESP
I believe it's something to do with the brake light error thrown up earlier, but may be wrong as not sure
SAM MODULE COMPARISON NOTE
After searching the internet i found the replacement SAM module but did notice a slight difference on Q code, mine being Q 002 and the new on Q001 everything else was the same including hardware and Firmware versions. I have listed a pic of both in case the issue is the difference between the two. When I purchased the replacement SAM module it came with a fuse box and relays, There was a staggered pin connection on the new fuse box that wouldn't allow the vehicle connector to connect to it including 2 extra pins, so I reverted to my original fuse box.
I would appreciate any help to guide me in the right direction to sort out and understand these issues.
Regards Alan
NOTE: Before refitting the new SAM module, I removed all 3rd parts wiring including tow-bar to start from a clean sheet
4. Rear brake lamp.
2.SRS fault
3 ESP
Regards Alan
