Mercedes Vito & Sat Nav
the_skatedoctor
Hi Everybody.
Im going to be installing a VDO sat nav system in my 54 plate vito dualiner.
Im just wondering if this will be an easy task?
Will i need wiring diagrams so that i can get the right wires etc?
Or will it be an easy like for like swap.
Ive done a search on the topic, but there is only limited infomation.
Thanks In Advance
T
the_skatedoctor
  • #2
Plug/Wiring Information
Help Needed.
Need help with wiring on the vito.
Ive seen the becker 1492 drawing, which is handy. But here is my wiring.
My Existing radio/cd is the Becker Audio 10 unit (Model No 6021)
A1 - SPARE
A2 - PINK/BROWN STRIPE ??????? Whats this for ?
A3 - SPARE
A4 - RED - Main Permament Supply
A5 - YELLOW/BLACK STRIPE ?????? What is this for ?
A6 - SPARE
A7 - SPARE
A8 - BROWN - Negative ground.
There is also a seperate 10 way plug with 2 cables used
1 - BROWN/RED STRIPE ???
2 - BROWN
I need a ignition supply which seems not to be present.
Any ideas
Coulsdon Eagle
Bexhill, East Sussex
Sprinter 310CDI
A5 - Yellow/Black stripe i believe is the ignition feed, Red being the permanent live (for the radio memory) when i changed the Audio 10 to my Sony head unit, i joined the Red and Yellow together, so the radio is no longer ignition controlled, dont know about you, but i hated the ignition controlled radio, there's not much chance of me leaving it switched on overnight etc, as i remove the face panel for security, which turns it off anyway.
Alfie
Surrey/Cotswolds
www.comand.co.uk
Help Needed.
A1 - SPARE
A3 - SPARE
A6 - SPARE
A7 - SPARE
2 - BROWN
Any ideas
That 10 way plug has your CANBUS wires in it. Pin 1 and Pin 2
