Mercedes W209 CLK 220CDI won't start crank when warm, fan runs at high speed
RR007
CLK W209 2005 220CDI
My vehicle is a CLK W209 220 CDI 2005.
My car start ok when the engine is cold. But when you run it for a while then stop and start, it wont start. No crank, Radiator fan runs at high speed and no glow plug light on instrument cluster.
Then if you leave it to cool down and start it will start as normal and runs well. when you switch the car on, if the glow plug light on instrument cluster comes on it will start.
When the car doesn't start ( no crank, fan runs at high speed, and no glow plug light on instrument cluster), the ODB analyser says cannot communicate with the ECU.
When the car is cold and can start, I get the following messages on the Analyser.
Transmission Control Module
P2311 - One of More messages from the Engine Control unit A not available on CAM bus \9 Cam time out fault)
P2312- One of More messages from the Engine Control unit A not available on CAM bus \9 Cam time out fault)
ECM - Engine Control Module
1664-4 Check Component N33/2 ( Heater Booster Control Module) Signal line is interrupted.
2356-8 N3/9 CDI control unit Recovery Error
2386-8 Replace component N3/9 CDI control unit, Internal fault
ESP Electronic Stability Program
C1022 - CAN communication with the engine system is faulty
C1038 Engine Control Module Not Identified or Incorrect control Module
Checked all fuses in the engine compartment fuse box.
Is this the ECU failing or other electrical issue with the car ? has anyone had this issue and got a fix for it ?
Any suggestions/help is really appreciated.
thanks
Uncle Benz
West Sussex
Mainly Mercedes
I’m with Star. It might be worth removing, inspecting and reseating the plugs at the engine ecu, and also examining the earth connections that are associated with it.
R
RR007
Any instructions/video's on how to remove it ?
I guess this is the correct way
R
RR007
Update - I had Mercedes mobilo road side assistance, called them today. Mercedes RAC guy came and scanned the car and found additional issue my scanner didnt pick up.
B1003-Communication fault with control unit N26/5 (Electric steering lock control module)
B1001 - Under voltage supply
His suggestion was to change Electric steering lock control module first.
The steering unlocks correctly when key is inserted and no issue rotating the key.
Is this the real issue for non-starting and ECU not switching on ? OR is this due to a failing ECU ?
Any suggestions appreicated
No, I think changing the steering lock will be a waste of money.
High speed fan running indicates a communication fault with the engine ECU, that your codes back up.
You also have codes that indicate there is an internal fault with the engine ecu:
  • Like
Reactions: DSK
R
RR007
Could I have 2 issues ? the ECU and failing EIS EZS ? I have seen on the internet that EIS EZS fails as well and need repair. There are repair or cloning services for this.
Do I first clone the ECU and see first ?
I would clone and see first.
R
RR007
I will clone it and see, ECU part number has been super seeded by 2 new numbers, I guess the original ECU part had an issue and they upgraded/fixed it and released as a new part number.
A 646 150 97 77CONTROL UNIT100ENGINE CONTROL MODULE001
A 646 150 50 91CONTROL UNIT100ENGINE CONTROL MODULE001Replaced by: A 646 150 97 77To Chassis: F 237024 To Date: 01/07/2007
A 646 150 64 79CONTROL UNIT100ENGINE CONTROL MODULE001Replaced by: A 646 150 50 91To Chassis: F 187913 To Date: 30/11/2005
Some are chassis/year specific. Match the bosch number and you will be ok
R
RR007
UPDATE - Sent the ECU for cloning, but they called and said there is a Software corruption. ECU communicates but its not sure what it is. He said part of the main software is corrupt and cannot be cloned. He is going to try again.
Options I have been given is to clear immobiliser details so it will work with the car ( Hopefully) or virgin the new ECU and get it programmed to the car.
How do you get a virgin ECU programmed to the car and do you know who does them ?
You program a virgin ecu using star/Xentry.
Vrigim ecu is the same as a new one would come from the dealer.
R
RR007
Thank you so much for pointing out the its ECU issue. Finally the cloning guy was able to read the software after heating up the ECU (Could be a faulty/cracked connection.)
Car starts and runs well. It runs better that how it was. no issues for now.
Thanks again for your suggestions.
Great! Glad your back on the road.
