Mercedes w211 2004 E270 CDI front doors controle modules battery drain.
valepk
W211 E270 CDI LH
Hello. I noticed that the front doors modules caused battery drain. I figure out that when I remove the fuses of the front doors control modules. How to determine what is the problem. I replace the door modules with second hand ones and the situation is the same, there is again battery drain. So may be there is something else connected to the front doors controle modules.
mersum1es
Finland
Is there any fault codes related to door module?
V
valepk
W211 E270 CDI LH
The drain is jumping from 0.02 to 0.05, 0.09 or so for a second. May be other control modules in the doors. There is some logic to be the two mirrors control buttons in the driver's door because it is the only common thing between the two front doors. I do not know :(
