Message from Mercedes --re lockdown/storage etc
I received the same email, not exactly that relevant to mine though...
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Had nothing from Mercedes apart from notifications that they've shut most of their premises.
Got this from Lexus though, which I though was a nice, if somewhat irrelevant, touch: -
We've extended your Roadside Assistance cover
until 28.06.21 at no extra cost
Hello Dave
In these uncertain times our customers' safety and peace of mind is our main priority. For this reason we will be extending your Roadside Assistance cover for an additional 3 months, at no additional cost to you. Cover for your Lexus RX with registration number D3YTS will now expire on 28.06.21.
In the meantime, for the latest updates on how Lexus are responding to the COVID-19 pandemic, please visit lexus.co.uk/covid-19.
Your Lexus Team
Srdl
Hampshire
GLC43 AMG 2018 (X253)
I had the same. I can see the paragraph
“Charge (SOC) should ideally be maintained at 50% and shouldn’t drop below 30%. You don’t need to charge the 12-volt battery as this is supported through charging of the High Voltage (HV) Battery.”
causing no end of queries from many owners who never think about batteries normally.
Full email below - kind of short of the call Mercedes buttons in mine :rolleyes:
UwxIO_3WgjynbIHYv9AJKCrWS3I3d4XxkL8hIGGHGBm6p3NNP1rPMYKYKjL-ASr3xP_v-B4yX65dtxWysu2R-lJULCab41kiaABLVzFxenFee8U_L2-24Tuf6uzD1on9NuE=s0-d-e1-ft
If you are not using your car regularly, we recommend starting the engine and letting it run for a period of at least 15 minutes every two weeks. It is important to allow the engine to run for this long so the battery can charge properly. Be sure that your car is outside when the engine is running and don’t leave it unattended.
PoAYg8QNoQ8sdvpQg_JEehrPftOxJz5_UI_UjVLpxJN2ka1fflp5jloPSt1gEaDaRl1EiXvIALrPtA5v03xktB5RF6W_3dXvHjE7BXVAVsg2fzvq_GOUd92eGhNE1x2OP0U=s0-d-e1-ft
If you haven’t driven in a while we recommend checking the pressure of your tyres – especially if you’re taking a journey on a motorway where higher speeds may be involved. If you don’t know what pressure your tyres should be the recommended pressures can be found on the inside of the fuel or charge flap. You can also view the current pressure of your tyres on the instrument cluster after driving for a few minutes on your next essential journey.
If your car has been left in wet or damp conditions, a thin layer of surface oxidisation can build up on the surface of the brake discs, which may mean they sound a little noisy at first. This is perfectly normal and gently applying the brakes when driving will help clear this.
hBCXsUoe43g8dt-mB3k4_pJl8-V0Ev5aSZ04vECVVayyfug-AcOIBSxLo_m0IqkaEe8G2f75oTARPu6S_s9I3ZjqhL6R7tbdFDrjyLNkaKMc4kbKq6AFhvODOavf9lRR4NY=s0-d-e1-ft
qjN5AY-ZyVclgJ7sWLnIS4NiRzD1oY02lYIwNCPwrbwfDrik7IxxG4cuscsJI_1eptLMMlrRHwQ0gCFf48OXXHc-DKjcoDM2fImMmwyvD_YvkotVyCsNHgxVQmqetTl7rLw=s0-d-e1-ft
Niv6O7zKsG36P9hfy0GEMMpJugB4h7tkJUJpv1fNNDl5FTFTbdQgOca3mX9ZpydZFIXtqpZDLiiedyMqj-DeHXsRjeKihMD9hsQHOjVOxz9rEnBU4c5TQcxkd6d8ATzR3xU=s0-d-e1-ft
If you’re not planning on driving your car for a long period of time, it’s worth considering filling up your tank to full to reduce the likelihood of any condensation building up.
qOFCg9MzrVQz-t5L40BcDtelmIuFsI3cSqv3DYOV78cgWiL4ibYeanzm-9ISIy35Mjgf8ixGUD2u83i_SIob-jFxC7QZAN8fTEM_OjDROvG2xDFWxyI14nS0mRNpBZhptPE=s0-d-e1-ft
on4c0g-dny0nTKa9Px36yozBBiYeudE-B9BQkleUMBeAbxZn2vpPOu7yNc26rfUy-ExFBD6s8ioEEdwvvLqbpOcWDohquUk4_wuSjDfsi2joJ-70vHzE0JAmBP0mfhFULWM=s0-d-e1-ft
Your car is coated in a nano-particle paint which resists grime and corrosion. However, if it’s regularly parked under a tree or bush, it’s good to give it a clean and remove any dust or dirt.
_cy_DDbfNqLPRodRTEHdrL4vnAWqiBOrZcqGuSj-WpKp2lj2qKG_RqGnuQ1i0kqKZjKZE_ah_UU5gy-58rYFnSWhj5yxJzIvQQbRaeH90TtGro3ln9EMHeG-v-ijEZJe-rk=s0-d-e1-ft
To support you at this time, we are temporarily extending the overdue service limit, so that you can bring your car in when the Government says that it is safe to do so. Your complimentary Roadside Assistance cover will also be extended in-line with these revised service limits. For more information click here.
The majority of workshops will remain open with a limited team to accommodate breakdowns and the service of key workers’ cars. A list of these workshops can be found on our website.
P8oSSKkDXTLbTiq8cUjlBRgJ8bHOgOJajNxlkLmyf6Nn6Oyn0zxDyBT-aMoGOJL6HfAY8nUIfhAUubIe2p3QmdPm9EXPn4GX5fiSdPPxNyXTS6HEC_9XXMem_jAVa-vNz3k=s0-d-e1-ft
As per government guidance, if your car’s MOT is due on or after 30 March 2020, its expiry date will be extended by six months, but you must keep your vehicle safe to drive. More information can be found on the government website.
BgiabSXISUD96FDcAea60ZvsvA304ybAlJIzrKcsquqJOPAh__9qEGLMNL6LwnohtUhaDRReoZqMUSllJZp_T-0LMSVl4YKIeyV9AjFilu0YtzhWuh6rEPx2-xc3E0rAFbI=s0-d-e1-ft
At this time, we understand that it’s more important than ever to feel protected. So, should anything happen while you’re out in your Mercedes-Benz, we’re here to help you with Roadside Assistance.
If you need immediate assistance press the
I0mgPGxLqXuW3nMzYodMSzJ5eT2kamCy1TOtHcOiGLX6DCgymjf8vO2LLuT0qQoOXU1zwO-AOxqKRQixPoV33Cb6aaerV9IC6ysHLIUh2dYOGglkaFrR-aYbyc9v64BwiMA=s0-d-e1-ft
or
yPSg2a4TECPfadjSykEgA3DpG_z08nJB3NT-MlX8d3k_TcOlDSAdc9TuQW7KxLVvVAVrzlh_2Flx37WLXEb7HacC78JGIAKQihNYdEOdpUBmWBaRcCCv8E8z3kxn7GI-Hlo=s0-d-e1-ft
button located by your rear-view mirror*, so we can see your exact location and access diagnostic information held by your car.
EmilysDad
Bury Lancs
ML350
I got my email yesterday.
I started mine yesterday afternoon for the first time in a couple of weeks .... no problems at all ..... went to Costco. First time out of the house other than to walk the dog or go to work. :)
00slk
Cambridgeshire UK
I'm going to start the 500 this weekend, not been started now since just after Christmas, best thing is the suspension is still on full height where I set it :shock:
I'll guess though the Halfords battery will be flat :rolleyes:
BillyBoy
W213 E400d All Terrain
I'm alternating between my E-Class and the wife's B-Class for the weekly shop, and taking the scenic route so they at least both get a good run every fortnight. Unfortunately both were full before the restrictions so can't take advantage of diesel at £1.09 a gallon :(
EmilysDad
Bury Lancs
ML350
....so can't take advantage of diesel at £1.09 a gallon :(
That's what I thought yesterday when I saw petrol at 99,9 pence per litre at Costco .....
I was in a diseasal ML with a 3/4 full tank :(
robparker
Taunton
I've been filling up the daily when required (not much at the mo!) and sneeking an extra can of cheap fuel home for the parked-up SL
Rory
Cheshire, UK
Took mine to Costco the other day - it's the only place I don't mind taking it due to the parking spaces. However, as we got there fairly early, most people had driven through parking spaces so were effectively reversed parked. :eek:
rorywquin
rorywquin
North Yorkshire
An old B-Class.
Have you worked out how much the few gallons of cheap fuel will actually save you in the SL?:shock:
Not knocking you, but it does tickle me when I read about those people that drive 5 miles further to save .5p /L.
Say 20 l @ saving of 20p/l = £4-00. Is it worth the effort?:)
However, I've recently moved to Yorkshire and I am amazed at what people will do not to pay an extra 1p.
robparker
Taunton
I have to fill my regular car up anway, so makes no odds
John Laidlaw
Wirral
Land Rover Discovery 4
The XC90 is used daily still to take the puppy to the woods for dog walking, the i8 every 3 days or so for the shopping ( being practical and all.....)
peterws1957
Lancashire
I got the same "we're here for you" type message from MB and other organisations as well. Weird that all these companies normally couldn't give a toss about me. Patronising and cringe worthy.
ZZZZ
Got a call from Mercedes today - the service D, originally booked for 27th of March, now re-booked for the 2nd of June, with courtesy car available the evening before, as previously arranged.
All the bits due confirmed (and it's a longish list), without prompting ... I'm impressed :rolleyes:
Srdl
Hampshire
Don’t speak too soon. Wait until the courtesy car is available and all the jobs are done properly :geek:
