David-ml270
- Nov 25, 2013
- Location
- Devon. UK.
- ML270Cdi. 2000. Turbo diesel.
I hope (touch wood !!) I have now sorted a couple of major issues with my new (to me) ML270. However, there's a couple of minor things I would ideally like to put right as well.
I always thought I was reasonably OK with wiring diagrams, but even with the full-colour version, I do find the Mercedes diagram less than user-friendly.
1. Fog Lamps. Basically - if I push the top of the switch (for the front lamps) - nothing happens. If I push the bottom - both front and rear come on which is correct. There's only one (green) wire to this switch from the AAM and what looks like a resistor between the two contacts so I'm guessing this resistor has failed. Has anyone ever taken this switch to bits - is that possible and/or can the switch be replaced or is it part of the centre panel assembly ?
2. Parking lamps. According to the handbook - with key in position 0 or no key in ignition - lighting switch in "parking position" and indicator in either left or right position, I should get either left or right parking lamps. I don't !
Can't work out how the circuit works and/or whether there's a separate fuse and/or relay for this function. Any ideas (Malcolm
Many thanks.
David.
Many thanks.
David.
