Mis matched tyres?
Freeatlast
C Class Estate 2011 C200CDI Blue Efficiency
So my secondhand W204 C200 estate turns out that it has three Avon ZV7’s on it.
Two on the front and one on the rear.
The other rear tyre is a Hankook (I’m not sure if it’s a Ventura or other design without checking)…
All tyres have reasonable tread and I believe that the Hankook is the oldest of the tyres (the three Avons being the newest).
So my question is do I keep the set up as it is?
Should I switch the ‘odd’ rear tyre and if so I presume that Avons all round would be better than Avon fronts and Hankook rears?
Does it make a huge difference (are the Avons and Hankooks similar enough to not give issues)???
Freeatlast
Freeatlast
I guess we are all a similar bunch - my OCD says to change the odd tyre for the £100 or so that it will cost, but my head keeps asking if I’m just wasting £100 and what the heck I’ll do with the odd. Hankook!! (Maybe I’ll try to find someone with 3 Hankooks and an Avon and arrange a swap)
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
I'd just wait until one of the rears wore down & then replace them both at the same time, but I am a tight@rse.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I would run with the current tyres & replace when one of the rears when it wears out. Not ideal but not end on the road.
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
The truth is there are so many cars about with a similar (or much worse) mismatch and they're not littering the ditches. However like some above it's a pet hate of mine and I'd change it. Having said that a factor is what you refer to as reasonable tread... 3mm or 6mm? And in checking it needs to be done right across the tread width to make a true judgement.
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
I agree with Malcolm210 100%!
I once bought a car with 3 differing brands on it - all good and the same size - but within a month I went and bought 4 new matching tyres.
To me it'd like watching someone who's left-handed try to do something that requires some degree of dexterity! I can't watch!
Rotorhead500
Very South Devon
Used to have a C63...
Oi...!!! :D
malcolm E53 AMG
As an aside - I was reading an article the other day that quoted one of the MIchelin execs saying “changing tyres before they reach the 1.6mm tread indicator is very wasteful as they are completely safe’. This surprises me on two counts one because it was commercial suicide and the other that in torrential rain the almost bald tyre would aquaplane and increase the stopping distance dramatically, that’s if you weren‘t spinning down the motorway out of control having just hit the brakes - I wonder if he’s still got his job
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
But then my OCD would be just as bad worrying about the tread thicknesses between the older Avon tyre on the same axle as the new one.
As Sonic suggests;
Get what wear you can from existing, then replace all four! I'm not sure that Avon are a brand worth having anyway?
Rotorhead500
Very South Devon
As Sonic suggests;
I've no problem with Avon. Ran their winters on a CLS and was very impressed, and looked at their ZV7 as replacement on last car.
Droverunner
West Cambridgeshire
Yes that's why I mentioned what did the OP consider a reasonable tread depth. I am tyre centric and if there are a mix of tyres on anything I buy and they are under 4mm I usually change the lot to start off properly.
RhodieBill
Well I disagree with Michelin's statement to a certain degree.
On Nokian Tyres they have two Warning Marks. One being the "Legal" Minimum Depth and another a "Recommended Wet Minimum Depth" shown as a Water Droplet Symbol. This being 3.5mm. As the Tyre wear the Numbers disappear.
See Video.
Rob7seven
Poole, Dorset
2024 B200
A Police driver, (I met him socially, not in any official capacity), told me that as a matter of policy, tyres on their vehicles are replaced when they reach 4mm. The way he explained it, that sounded like a countrywide policy, not just the local force.
I don't do a big mileage these days, and tend to replace cars when they're out of warranty. That means that I've bought very few tyres over the years, but the Continentals on my C300 do seem to be wearing very quickly, the rears aren't going to reach 10,000, and as far as I can remember, all my previous tyres have managed about double that..
