Misfire CE230 1990
jeff605
Hi, My 230 had been standing for about thee weeks, started it up but it took a while, usually first go , and ran a bit lumpy, so took it for a run. Misfire got worse, appears to be running on three cylinders. I've changed plugs, checked leads and distributor and not found anything obvious. Is there a " standard " fault causing this I should be aware of, if not any suggestions of where to look please Jeff
This would often be condensation in the dizzy cap and rotor
jeff605
Misfire
Hi, I've been laid up myself with a bad misfire for some time ( !! ) so haven't got back to this yet. When I'm back in action I intend to check all associated plugs/sockets for damp/dirt/corrosion now I've read up on the ignition system. As the fault developed while the car was standing - and the weather was more than a little wet - I suspect it will be something like this that has caused the problem. Will update after these checks. Jeff
