Vidanova
- Jan 30, 2022
- Location
- Portugal
- Website
- algarvevillaforrent.com
- 250E 2016 Bluetec 651 Diesel
Hi Folks Newbie here! Been reading all the posts on the subject but now I am stuck.
Bought a 2016 Bluetec 250E in October 21, 69000Kms. Got EML after 60kms, seller told me to take it to Mercedes dealer and they would reimburse me, so far they have. Merc dealer #1 replaced front front NOx sensor. Went on holiday with it after 300 kms got EML and check ad blue. Went to a new Merc Dealer #2 as was 400kms away from home, showed the invoice for front NOx sensor that had been replaced and they did diagnostic and said it was the other rear one. Waited a week and they replaced it and did a "Program Command Module Coding (after quick test)" as well. 1500 kms later EML is on again, my 10$ OBD 2 shows code P2201 NOx Sensor.
So I have scouring this forum and have discovered that the emissions recall can/will cause NOx Sensor failures and that the sensors should both be replaced at the same time and reprogrammed, and only with the latest Mk3 sensors. I also did a VIN search and yes my car had the emissions recall done. (no Idea when not sure by who and if NOx sensors were replaced at that time...but doubt it) who knows?
The first workshop replaced the front with A0009053403 and the second workshop replaced the rear with A0009051412/80 this I took from the invoices.
So I looked up part numbers on https://www.ilcats.ru/mercedes&language=en/ and it gives A0009053403 for both. I assume that these part numbers are the original Mk1 crap ones. So to cut a long story short it seems the first workshop replaced the front with Mk1 and the 2nd Workshop with Mk2 or Mk3, no idea.
I need to sort this out but need to know the MB part numbers for the Mk3 so I can make my case, can any one help with this or suggest where I can find them, I suspect that only MB service bulletins will have that, but want to go to them forearmed with the correct info.
Thanks in Advance.
Sorry for my first post being so long.
PS. I have done a write up step by step of chain, sprockets, oilers, guides, tensioner, replacement for an 87 SL560 if anyone needs it.
Thanks in Advance.
