kebo57
I have had limp mode occurring progressively over the last month up to about three our four limp modes a day
But now its stuck in limp mode I would say stuck in second gear 30 mph = 2500 rpm
When I select reverse I get a clunk & slight lunge back wards
Then when I select neutral its slightly smoother no lunge
Then when I select drive I get the same clunk and a slight lunge far wards
Same as above when I go back to Park
I've had a few clunky changes over that time usually goes into limp after the clunky change
Also when you brake with out stopping and then accelerate it sort of looses its self and goes in to limp mode.
I've been careful with the box over this time
I've dropped the oil and pan today and its clean not bits, oil still has a reddish color it lookers better than the other times I have inspected it, oil level is OK
I've disconnected the battery, changed the MAF, still stuck in second gear
I'm going to Frank Masseys to morrow to get the codes cleared hope this will help
AS usual any help would be gratefully appreciated
Kevin
Kevin
