kebo57
just done the engine oil change no problem but I removed the plastic under body shield to have a look at the auto box, I read the thread about auto fluid change I found the electric plug front right with tin cover over it also the tube middle right going up to back of engine also the thread talks about removing the wheel arch trim, exhaust, turbo bolts etc. But it looks like there is plenty of room to drop the sump maybe I understood this wrong and does the dipstick fit in the hole where the tube goes can the job be done with out removing the wheel arch trim, exhaust, turbo bolts etc
