ML 270 cdi: diesel leaking into gallery around injectors
Brian Williamson
HUNTINGDON, CAMBS. ENGLAND
ML270 CDI AUTO/2001/2.7L DIESEL
I am new to this site and having difficulty just trying to find my way around. Our 51 plate ML 270 is leaking diesel into the gallery around the injectors. We have had the egine bay washed and the leaking diesel appears fresh and clean.
The problem seems to occur only when the car has had a period of normal running but does not happen on tickover, even for an extended period. It has been suggested the cause might be small o ring seals on the return/leak off line above the injectors. I hope that makes sense as I am not familiar with the technical names
Would you agree and if so is the cure simple?
If you dont agree what would you diagnose please?
Naraic
2005 CL500.
If that's what it is...then yes an easy fix.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Or the thin return lines from each injector are perished they are rubber after all.
jib
