ML 270 CDI drive belt ?
goonerpete
ml270 cdi
I have noticed a split in the belt at the front of the engine linking the alternator etc.Does anybody know if I should be worried by this,and if so is it expensive to buy and replace,either by myself if it is a straight forward job or by a garage if its not a long job to do.Also if it were to snap then would it cause big problems.Is it a timing belt ? Thank you...P.S its a 2000 model
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
i may be a prob but an easy change slacken the tensioner remove belt and fit new retighten and off you go not to expen for a new belt either
G
goonerpete
ml270 cdi
Thanks for the quick reply,I can relax a bit now :)
Xtractorfan
S class
No its not a timing belt, it has many names, a poly belt, serpentine belt, alternator drive belt. grooved v belt..basically fairly easy to change, the biggest problem is remembering how it is routed...it isnt a big job but it is slightly awkward for the novice, so I would suggest getting an indie to change it as it shouldnt cost a lot...
