Hello everyone, a bit of help please with a problem that has been diagnosed with my 2003 model ML 270 CDi with 45k miles.
It has been running fine until recently when the weather got colder. It proves almost impossible to start when cold but the glow plugs were replaced only 9 months ago. It's never a problem when the weather is mild but the last few days it just won't start as normal when the outside temp drops below around 2 degs. It turns over without any problem (new battery 1 month ago) but it does seem to have a smell of raw diesel coming from it once it gets up and running and it's also a bit smokey when it eventually starts after about 5 mins cranking!
Anyway, my local garage has it now but they can't find any fault codes. They noticed a little bit of diesel around one of the injectors and they simply tightened it down more. They did however, tell me that it has low fuel pressure but don't know what is causing it
Any advice will be greatfully received and I might just have a bash at fixing it myself if it's not too complicated.
