ml 270 cdi not upshifting until 2500-3000 rpm when warmed
tsu
ml270 2001
Hello to everyone,
I have an ml 270 cdi 2001 . A few weeks ago and i started noticing that after about 100 kilometers of driving it starts to not shift up until at least 2500 revs .If i let it cool down for an hour it will be shifting normally again. When it doesnt shift up until 2500 rpm its also very aggresive on the downshift making the whole car jolt when decelerating. Once a week it will also throw itself into neutral randomly while decelerating. All that has changed within 2 months is swirl flap delete and turbo vacuum actuator. Does anyone have any experience on this matter? Any suggestions would be appreciated.
When did you last have the atf changed?
Taffy7hfa
Oxford
Definitely worth checking the atf level before you do anything else, then check the TCU for fault codes.
it sounds like there will be some.
