ML 270 Running in ECU 'Limp' Mode?
richbrowne
Wiltshire
www.GuildAssociatesLtd.com
I own an ML 270 and it has started to intermittently run in ECU 'Limp' mode. The disc pad warning light and brake fluid level lights started to come on (fluid level goes down slightly with disc pad wear) with the 'usual' beep from the dashboard to indicate the issue.
Approx. 20 miles after the pad warnings, power was substantially reduced and it will not exceed a certain speed.
I initially thought this 'Limp' mode was due to the disc pad wear but I have since been told that this does not induce 'Limp' mode.
Does anyone know what could be causing this please?
Thanks in advance.
Rich.
