fastboysparky
If i accelerate hard whilst turning when my ml is not up to temperature i get a whining noise which then stays until engine is thoroughly warm. If driven slow from cold there is no problem. Any ideas please.
tom7035 said:There may be some connection here with the power steering pump, you may have air in the system.
I would try bleeding the power steering system. Jack up the front of the car and with engine off, fill the reservoir to about a half-inch from the top. turn the steering full lock to lock several times, topping up if necessary. Then have someone else start the engine while you keep an eye on the reservoir and be ready to further top up as the level may drop quickly. Finally, with the engine idling, turn the steering about a quarter turn in each direction several times. Switch off, allow to cool again and do a final top up to the max mark. This procedure should clear any air from the system.
No-cost and worth a try I think.
QUOMAN said:*****FROM POWER STEERING SERVICES*******
jacking up the car takes the weight off the vehicle so the valve in the box wont operate correctly. as its a whine not a grumble with,i assume no loss in fluid this is un necessary to bleed the system KEEP THE WHEELS ON THE ROAD then turn lock to lock. why may the level drop quickley? a blown high pressure hose would make this happen, but the hose is ok.
sorry ,but this is NOT the way to bleed ANY car
mmm..... how have Mercedes and BMW managed to survive ...........QUOMAN said:merc,like bmw use luk pumps and to put it mildly.....their crap!!
QUOMAN said:beats me tom,btw you dissagree with the way we "bleed" a self bleeding system, please tell us your viewsas, when the wheels are lifted from the ground the valve all but ceases to function
Yes you may well be correct re. the pump. It's the 'accelerating while turning' which led me to think of a steering issue somewhere, or a fluid level surge. It's a bit vague and it's never easy to diagnose 'from a distance'.QUOMAN said:i stand by my opinion that it is a bearing noise probably from the pump
it's not the drive belts, the noise only starts if you accelerate hard whilst cornering.Silver Arrow said:Are you certain that the drive belts are correctly tensioned?
These can cause whines when starting from cold as the load on the altenator is initally high, then drops off which reduces the tendancy to slip at higher speeds.
it is definately not an engine noise.blassberg said:is it definitely an engine noise or could it be from the drive train?
ok guys. Now you have finished. Can you translate it into laymans terms. I am only a mere sparky. I don,t even know where to check the power steering fluid. Perhaps someone could tell me where to find this first. Thanks.tom7035 said:Yes you may well be correct re. the pump. It's the 'accelerating while turning' which led me to think of a steering issue somewhere, or a fluid level surge. It's a bit vague and it's never easy to diagnose 'from a distance'.
Glad we haven't fallen out over the 'bleeding' issue.
I think we should let some others come in here with suggestions.
(P.S. Only 20 years? You're not even half-way yet!)
fastboysparky said:If i accelerate hard whilst turning when my ml is not up to temperature i get a whining noise which then stays until engine is thoroughly warm. If driven slow from cold there is no problem. Any ideas please.
