ML 270CDi Problems - what should I do next?
cumbriamoose
New Registration
Cumbria - obviously LOL
I have recently bought a ML 270 CDI - amazing car - but am having problems.
Just after I bought it (second hand) it started losing power, wouldnt shift down under hard acceleration and wouldnt go past 2000 revs.
Took it to the local Merc garage where they diagnosed both cats had gone down and the Air Flow Meter.
Contacted the garage where I bought it and they took it back. They just changed one cat as they said the other didnt need doing and changed the air filter as they said that was giving false readings to the AFM. Took it home - brilliant power etc
And then it all started again. But if I pulled over and turned off the ignition and restarted it, the problem disappeared. So rang garage again and he said he would pay for new AFM
So had that fitted yesterday. Drove home - brilliant (again)
But this morning the old problem has returned !!!!! Turn the iginition off and it disappears! Arghhhhh!
So my question is:
(a) any suggestions on the possible cause of this problem? or do I take it back to the Merc garage for further analysis?
(b) Can anyone recommend a good independant Merc specialist in the South of Cumbria - or nearby?
panason1c
Somerset, UK
There can be many reasons for your ML going into 'limp' mode...........a faulty maf can cause it but you've had a new one fitted so we can rule that out.............
Best now to stick with the garage you bought the car from and let them sort it..(presumably there is a warranty?) as it could get quite expensive for you if you go it alone.
Unless a cheapy has been fitted, this does sound a maf problem still
BlackC55
South coast
C43
Possible causes:
EGR
Inlet port shut off
Vacuum transducer(s)
Turbo (unlikely)
ramstar
cdi 220 losing power
my car wont go above 2000 revs,i reset the memory and it was ok till i floored it a few times then it went again,ive disconnected the maf to no avail.its had a full sevice,any help please.cheers
