- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Dieselman will answer soon, he is the best on diesels that you can get
Hello
I have noticed a problem with one of my diesel injectors. It hs developed a glass like black crust over its surface and the cabin now smells of diesel when the engine is running. I have looked all over this forum and found it to be a fairly standard problem.
From what I can understand from reading several posts the problem lies not with the injector but its seal to the cylinder head. Is this correct or has my injector got a possibility of leaking from its body ?
I was wondering if I could just purchase a new seal from MB and spend the time cleaning the crud off to remove the injector and simply replace its seal ? I should point out the build up has completely covered the fuel injector and electrical plug, it can no longer been seen.
Also my fuel economy is awful, around 17MPG ( urban ), is this a side effect of the leaking injector ?
Any advice greatfully received.
Jon
