Hi i have had a ml430 for a few years with lpg on it. Last winter is stared playing up, everytime it switched to lpg it would run badly and misfire and cut out at junctions so i stopped using it on lpg, in about april time when it was a bit warmer i tried it again and it was fine, done a few thousand miles since then and its never been a problem. Ive had it parked up since the end of august until the start of january, and guess what its running horrendous on lpg again.
Lpg guys have had a look and they havent got the software to get it on there laptops.
A guy at work has a old disco with lpg and his did the same, apparently lpg needs a hotter spark? he changed the distributor cap and rotor arm and that solved his problem, but the ML has electric coil packs!
Think i will have to run get it on a STAR computer while its running on lpg to find the fault,
Does anyone have any suggestions?
cheers
cheers
