ML Pollen filter
Jack_igm
Hi All,
My ML270 CDI has virtually no air coming out of the heater vents.
Could this be a blocked pollen filter?
if so where is the pollen filter located on the ML and how difficult is it to change as I know the V-Class is a nightmare under the dash board, is the ML the same?
type49
Nice & easy. Remove the dash undertray behind the glovebox & you should be able to see the "letterbox" type cover that it hides behind.
