ML270 Battery change
tony.martin5
FRANCE
ML270/2002/CDI
Hi all, I need to change the battery on my ML270 CDI 2002, will this affect the ECU or will everything reboot on power up ?. I did this on a Volvo s60 and had to rig up a temporary battery to prevent a visit to the dealer.
Rockall
Donegal Ireland
Many
Changed battery on a 2001 model a few weeks ago - just had to reset the radio code. Noticed that the autobox was changing smoother after the reboot:)
Regards
Bill
Turning the steering wheel from lock to lock by just driving it will turn the ESP light off, you may have to reset the windows, other than that no problem :D
Jdokal
Mercedes
Regards
Bill
Really? Why did you change your battery? Was it dead or was it showing a low voltage?
Rockall
Donegal Ireland
Many
It just literally died overnight - no warning or sluggishness and would not hold a charge when I put it on the charger - it actually looked to be the original which is very doubtful but...
Regards
Bill
This is typical at the first frost, it finds the weak batteries, changing it now means a trouble free Winter
Jdokal
Mercedes
Thanks Bill and Television. I will have a look at the battery and make my conclusion.
Was it difficult to remove the battery Bill? Television did send me the instructions last year, however I did struggle and ended up putting the connectors back on and just cleaned the battery up.
Rockall
Donegal Ireland
Many
Sorry only seeing this now - max 5 minutes in an almighty rain shower. 11 mm spanner from memory and had to remove a piece of rubber trim around the edge of battery compartment - obvious when you look at it.
Bill
Jdokal
Mercedes
Bill
How does the battery rubber trim come apart or are you talking about the top rubber bit that just pulls off?
T
tony.martin5
FRANCE
ML270/2002/CDI
battery change
Thanks everybody for info on battery change, it all went well, I had to do the steering lock to lock to get rid of ESP warning light, no trouble with windows, an immediate improvement in gear changes, much smoother and more positive, Battery is awkward to remove, I took off the rubber moulding on the rim of the enclosure and loosened the whole surrounding by taking out one screw at the bottom right (13mm) my battery terminals are 10mm nuts. Thanks again for all advice.
