ML270 CDI fuel consumption
Northseatiger
Scotland
Evening all. I've just join the forum and wonder if I can put a question to all you ML 270 diesel drivers. I've just been on a long journey in the ML and was a good boy and sat at 75 with the cruise control on for a full tank. I had a full tank when I left the house and I had to tank up after 420 miles (74 litres). What is everyone else getting? Is this bad? I thought they were meant to get baout 30mpg average and on a long journey I thought I would have got about 500 miles out of the tank.
Should I be taking the ML in before the warranty runs out? Anyone got any thoughts as to if this is average or below par?
Cheers
Alan
230K
Belfast
E300TD/1998/3.0 Diesel
25.8mpg is not as good as i thought it should do, we went on hols with another family in an M270cdi and did 2400 miles our 210 estate 300TD with roof box an 6 on board did just over 30 cruising at 80mph and the M class fills were very very slightly bigger than ours i reckoned she was doing 28-29.
Check your tyre pressures and keep them at the high end of the scale to see if consumption improves.
230K
panason1c
Somerset, UK
My ML270 (auto) varies between 27..29 mpg although last year, on a trip through Spain i averaged 33mpg at cruising speeds of 80mph.
I think that cold weather increases fuel consumtion.
As mentioned previously, check tyre pressures (29psi all round) and also check the condition of the air filter.
N
Northseatiger
Scotland
So how many miles to a tank does that mean you get? I get the warning light up at about 390 miles from a full tank.
panason1c
Somerset, UK
Cant really say how many miles to a tank as i fuel up randomly from various levels (reseting the odometer trip)...i then divide the miles travelled into the gallons used since my last refuel to ascertain my mpg figure.
