ML270 CDI glow plug lamp coming on
Staffs ML270 CDI
Staffordshire
Help!!
My ML270 CDI 2002 has a problem, first start in the morning ignition on, glow plug light goes off, I start engine and after a few seconds light come on again and stays on for a minuite or so, then goes off and stays off........
Any suggestions?
Cheers all
David Pemberton
Hello
Probably a faulty glow-plug. If the ML systems works like the C system then the cycle goes something like this:
Ignition on starts pre-heat
Light goes off to signal end of pre-heat
Start engine
Glow-plug control module initiates after-heat (to improve post start running) for up to three minutes
Glow-plug control signals faulty plug by keeping light on during after-heat
You can confirm by checking wth a basic multi-meter.
See thread here: http://forums.mercedesclub.org.uk/showthread.php?t=29073&highlight=c220+glow
Best wishes
David
(I've only ever sat in an ML once, but this sounds so like the other glow-plug problems that ever read about that I'm venturing a guess!)
Staffs ML270 CDI
Staffordshire
Hello
Start engine
Best wishes
David
David,
Many thanks for your reply, I will organise to get the car in and get the glow plugs checked out. she done 70,000 so maybe its worth having the lot done................lets see what the cost is first O:))
Regards
Darren
panason1c
Somerset, UK
Precisely the same symptons that my ML displayed...........It was one of the glowplugs that had failed, i renewed all of them and have kept the old 'good' ones as spares.
From memory....they are about £12 each from MB and easy to renew.
W
W203-C220
Stockists for Beru Glow plugs
The GSF branches are found here - http://www.gsfcarparts.com/contact/branches.asp
Mercedes spares price for these same parts (with the MB logo and additional part number on them) is £13.77 +VAT. Roughly double the OEM part cost.
You may find it easier to source these locally once you know exactly what you require which is Beru GN003 type.
I have also posted a reply with useful links on the other thread by the way :)
Best of luck anyway, it's no harder than changing spark plugs I found.
Regards
Kevin
C220 CDI (2001)
Now with fully functioning turbo thanks to a new MAF!:D
