ML270 diesel run for a few seconds
Got a guy with a ML270 diesel that fires up and stops after a few revs,,any idea on this one please
kebo57
Lanc's
ml270
Hi Malcolm how are you keeping & great to see you back
Could be leek off rail air lock our possible injector passing (sort of acceptable pressure when ignition is on but when starting the injector passes enough pressure for ECU to stop engine) is there any lights associated to the problem
Kevin
colechelle
Resigned
have to agree with the other 2 posts malc,could always be the good old cps!!!!
Thanks the car belongs to my local garage where I do some work, the battery ran down and the fault appeared after that.
ah, could be the das 2 controller then!!!
Thank you again, he said that he changed the ign switch, but I cant see how he could do that without Star
