tttonyyy
- Mar 31, 2019
- Location
- Southampton
- '03 ML270 (owned from 60k miles, now on 90k+)
So here's where I'm at:
It has on-and-off taken a fair bit of cranking to get started, this is intermittent and getting worse.
I replaced all the fuel pipes with fresh ones and fresh clamps. There is no evidence of air bubbles in the clear pipes between the low pressure lift pump and the high pressure pump.
I've just replaced the high pressure pump with a reconned one that's been tested - and now it's worse than ever.
No fault codes appearing - though there were historic ones for:
P1187-001 Rail PRessure monitoring: The maximum pressure has been exceeded
P1197-032 Rail pressure monitoring: Control variation below 1500/min (rpm)
I have cleared these and they have not recurred after multiple starts now.
If I disconnect the fuel tank and feed fuel from a raised funnel directly into the fuel heater before the filter, it is then much easier to start.
So I am currently suspecting the low pressure lift pump - has anyone experienced the symptoms of this failing?
Once it has started it runs fine, no stalling.
