ML270 will not rev past 3000rpm
zac
Swansea, South Wales
Came back off holiday and took the ML out after standing for a week but it will not rev past 3000rpm and the kick down will not work, it started ok and rev's up to 3000rpm ok but will not pass it, (like a rev limiter) HELP!!
psmart
A lot of ML problems at the moment!!!! Basically car is going into emergency mode, but it could be anything without more info. Have a look at the ML270 thread in the technical section and see if you can provide some more information so we can help. It may be something simple (I hope).
Z
zac
Thanks, The car appeares to be running fine up to 3000rpm but will not kick down or pass 3000rpm, there are no other symptoms of faults??
12RM
Scotland
Maybe the "system" thinks the box is in nuetral or park? That will inhibit revs higher that what you are seeing IIRC. Another ML owner here could confirm that.
I know this is the case on other MB cars.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
battery voltage is low at a guess, let it idle or take it for a drive, better still charge the battery see if that helps. Could even be the batteries had it!!!
jib
As jib, do measure the battery voltage in the morning before you start the car, should be around 12.5 volt.
Have you tried unplugging the MAF
Z
zac
Had it at the dealer today (SG Mercedes Swansea) it turn out to be the maf sensor was faulty they replaced it and all is fine (for now!)
this was the dealer that did not responed to a complaint that i issued to them after they failed to identify faulty engine mounts,(vibration problem) after discussing it with them the agreed that they were in the wrong and only charged me £80.00 for the work today, nice to see dealers do have a heart!!!!
