ML270cdi automatic gearbox oil change
si69b
Leeds
ML270 CDI
Has anybody got a PDF file on how to change the oil in an automatic gearbox for a ml270cdi.
Also how often should the oil be changed?
It is the same box as in the DIY section for a 210.
You will not have a converter drain plug if after 30-09-99
We recommend ever 40k miles
