ML350CDi runs out of fuel at quarter tank
Mark Bowers
ML350 CDI 4Matic 2011
Just wondering if anyone can help, my 2011 ML350CDi runs out of fuel at a quarter tank. I have read it uses a venturi effect to level each side using the return from the common rail. If I have read it correctly I should be looking at the high pressure pump.
Can anyone confirm this??
mersum1es
Finland
Yep, insufficent return flow or faulty /logged venturi system was problem older ones...
M
Mark Bowers
Thanks for that, is there anything else that could cause insufficient flow. Whilst testing it using live data I did notice the pressure was low at higher revs.
mersum1es
Finland
fuel filter, very leaky injector, bad hp pump...
Tel: 020 8863 9233
