ML63 Charging Voltage suspect?
Nawaz SouthSudan
ML63 2007 6.2 AMG
I bought an ML63 6.2V8 in November 2017. The starter "felt lazy" so took it up the motorway - 200miles later - no improvement. The charging voltage after 200 motorway miles was an indicated 12.4V on the dashbord.
So changed the battery for a new MB from dealer in March 2018. No improvement.
So changed the alternator - new MB from dealer in June 2018. Charging improved to 13.4V to 13.7V on the dashboard. When measured with a Fluke, it is over 14V.
2 things:
1) Starter still "dips speed" on cranking-turnover - even with a warm engine before ignition...
2) Very puzzling: when you "blip the throttle" - voltage goes down before increasing? How?
1) Possibly faulty starter?
2) There is a one way pulley on the alternator and active charging management by the engine ECU. This will remove/reduce charging under certain conditions (overrun = max charging, revving or full throttle = minimum charging).
Nawaz SouthSudan
Nawaz SouthSudan
ML63 2007 6.2 AMG
@alexanderfoti - Thank you. Now - is there a way to test the starter for a fault like worn brushes, partially overheated windings?
New generation mechanics - replace modules... not repair.
Point 2 is very silly of MB to do... - I have the "devil's chariot" - an X6 4.4 Twin turbo - with similar setup... causes no end of problems with the battery...
The one way pulley is there to save the life of the belt, as the alternator has a lot of inertia with rapid speed changes.
The active charging management is all in the quest for better fuel economy!
There may be, but I do not know how. This would be the domain of starter repair places , or motor rewinders. You could extrapolate based on the current draw, but I don't know what the right value would be.
Have you checked grounding straps aren't missing etc?
