dodd1980
- Aug 19, 2012
- Location
- Weston-Super-Mare
- CLK500 2003
I've been searching a lot of forums for an answer but seem to be going round in circles.
basically the passenger side only blow cold air even when the heater is in maximum heat. Driver side works perfectly. The rear doesn't seem to get much flow and not really hot/cold but just ambient.
Various forums suggest heater control valve under the brake master cylinder but I can't see it being that as a single valve would stock all heat surely. I've had the glove box out but can see anything obvious that is not moving.
Open to suggestions/ideas as I'm stuck
Sent from my SM-A715F using Tapatalk
