Can't tell you for your model, but I do know on my W210 that its a doddle to install one.
The 'brains' is installed at the front of the passenger footwell, which is dead simple to access and has loads of space. The wiring just takes a feed from the back of the radio, possibly the most difficult bit will be fitting the bit of plastic trim that holds the phone cradle in place.
BTW I wouldn't recommend a bluetooth handsfree, they sound awful to anyone calling you on the move.
The Merc kit is not really an option - not sure if you can even get it after market and its very expensive.
I can recommend the Nokia kit (CK7W). This has bluetooth which I have had no problem with, even at speed, and the option of an additional cradle if you want one provided you have a nokia phone. I have one in the jeep and its fine. Works with both phones over bluetooth and has a cradle for the wife's phone of the week. There is also a kit on the market called a 'parrot' (Its french) which appears pretty good and has displays, memories etc.
The Nokia kit is around £60-70 online and easily fitted if you are fairly competent with a screwdriver, though you will need to get to the back of the stereo to connect up the mute. If you don't have a cradle, then there is just one small button visible so its very neat. Failing that, fitters will put one in for around £200 - £250 all in. If you do want a cradle, you can get either MB (£100 ish) or after market mounts that blend into the dash and make it look like its always been there.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
