turnipsock
I was putting in some helicoils on the ignition cover of my 320CE and noticed that the wires going to the 1-6 coil were exposed and probably touching each other. There seems to be a bit of corrosion there as well so it's probably been like that for a while. It looks like they had hardend due to the heat and just fell apart.
I'm not sure how to go about repairing this as the wire seems to buit into a moulded section and then this disappears into a loom above the inlet manifold.
I could just repair the two wires and cover them with heatshrink, but the same problem might be about to happen on the other two units.
Has anybody replaced this load of wires and what is involved?
