Movement when parking brake is on?
ElegantSpoon
Hellooo!
I have had my 2004 C230 for just over a week now and I am enjoying it so far. The only question I have is that when I put the car into park and then put the parking brake on it moves forward slightly once I lift off the brake.
Is this normal with a mercedes auto?
Any info on this would be great!!
Thanx
Mike :cool:
bigtwin
Banned
What do you mean "when I lift off the brake"?
When you lift your foot having applied the parking brake? - Not normal.
E
ElegantSpoon
Hello :)
I mean, arrive home, foot on brake, move into park, then apply parking brake with left foot, then lift off brake and the car moves a little.
Like the handbrake is a little slack?
bigtwin
Banned
Hello :)
Someone will be along in a second I'm sure with C specific info - on my E it doesn't settle at all - firm as soon as the pedal is down. My old Disco however used to move about 3/4 mile as the thing tightened!
Does it hold firm on a hill on the brake alone?
Yes that is normal,, my SL moves a touch when I do that.
the parking brakes are not that good and most of us just leave the car in P for the best part
E
ElegantSpoon
Do you mean the parking brake when the auto box is not in park? I have parked on a hill ok with it in park and parking brake on but it does have that settle in movement.
bigtwin
Banned
Probably absolutely fine then - I'd find a hill and put the brake on with the box in N just to make sure it's doing what it should then you'll know.
As said above - lot's of us never use the thing at all - I don't unless I'm parked on a hill, in which case it makes me feel better!
E
ElegantSpoon
Hello Television :) if its standard practice wanted ice then thats alright. I just to make sure as with manuals theres not normally any movement.
E
ElegantSpoon
I will find myself a hill this week then :D
By the sounds of it I'm guessing its probably ok!
Thanx for the help!
My driveway is on a slope and there are times when I think that it will go into the garage after I have applied the parking brake and then go to P and take my foot off the pedal
stumpy
various
Both my Mercs roll an inch or two when the parking brake is applied.
hairyg
Worcestershire
www.vegetarian-and-low-calorie-recipes.com
R129 (1994) SL320
My experience is the same as Television's. The car settles as the footbrake is released. My driveway is a 1 in 4 slope and either Park on the auto box or foot operated parking brake will hold just fine, but I always use both. It makes no difference if the car is facing up or down the slope.
My old C200 auto did the same.
davidsl500
My SL moves as well when on a slope. I usually apply the parking brake and let it settle before moving to "park". My old Jag used to be a bugger to get out of park on a slope if you let it move forward in park before setting the parking brake..
jubhi
Birmingham
E350 CDI Sport Coupe Brabus D6-III, A150 SE, Honda CBR1000RR Fireblade
Mine does it also and so does my Dad's C-Class, it is normal on Mercs so don't worry.
Myros
R107, S211, R170, C219
all ours move differing amounts
from barely perceptible on the 202 to a couple of inches on the 124. As long as it stops eventually, and not too far down the road, it should be alright.
I put the service brake on and operate the parking brake while selecting P on the autos, hoping to keep everything nicley equalised and balanced out.
paul c
Mine also does moves a bit its a manual box i think its fairly normal.:)
Micman
C180K Avantgarde SE
I think that is common on all Automatic cars to move slightly after you have selected park and then release the footbrake.
I've noticed that in other auto cars - it's not just a Mercedes thing
