Hello and welcome, your fault is not very common. The level of the transmission fluid is more critical for reverse than forward. Are there any noises, does moving the gear shift slightly do anything.
Thanks for your reply, I will try moving the gear shift slightly tonight. I have changed the filter and transmission fluid and dipped her when she is warm and the level seems to be ok and there dosent seem to be any real noise.
As I said earlier, nothing listed for this fault,its never come up on the forum, and for whats its worth I have only heard of 1 and that was mine,but on a BW box and that was a sticking valve in the valve block.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
