My 1978 W123 Mercedes-Benz 280CE got fully restored (including the engine) less than a year ago. Recently the engine hesitates. The worst case is that it can only go up to 30km/h. The mechanic told me that I was running it with extreme low fuel level and therefore sucking up the residue at the bottom of the fuel tank. After that the fuel pump, the fuel hose & filter were replaced. The fuel distributor & injector were also cleaned up. However, the situation only improved but not solved. When I accelarate hard, the engine is still choking. Even if I accelarate "smoothly", the car cannot go above 100km/h. Should I consider to replace the Fuel Tank or if there is anything I can do to solve this problem completely? Please help me...
