My key is stuck
EvaG
Hi My key is stuck in the ignition - I can start the car but I just can't get the key out - any thoughts?
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
what car is it ? have you tried wobbling it in each of the different positions ?
stumpy
various
Mine did the opposite once. Could get the key in and out, just couldn't turn the ignition. After much joggling it freed itself. Have you tried swearing at it?
E
EvaG
I've done a lot of swearing at it funnily enough - I've also flooded it with WD40 - the hammer is next (unless it's stolen first) - someone is bound to realise the travel rug over the steering wheel every night is suspicious!
E
EvaG
Ooops sorry - me again - it's the 190e auto 1988 model (E reg)
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
It's time for a new ignition barrel. Order from the dealer and it'll take about 5 days to arrive, keyed to your car. You'll need the V5 and ID to order & collect the barrel
Do not remove the key till the new barrel arrives & is fitted otherwise you're likely not to be able to get it in again. A large bill will then result
Nick Froome
www.w124.co.uk
planetwheels
hi, i carnt turn my s class on, the key wont turn at all now, any thoughts, cheers
The chances are that it will need a new barrell or DAS lock.
What is the first 6 VIN number WDB------
Malcolm
www.W140.co.uk&www.r129.co
