My R230 irritations, help !
Comfy chair required
wrightkarl
wrightkarl
Malvern
210 E320, E430 - 211 320CDi & CDi Sport - E350CDi Sport - 215 CL500 - R129 SL500 - R230 SL500
  • #23
Update. Oil leak found, larger of the two expansion plugs at rear of engine, ordered merc part for £10 and will fit in 5 minutes.
Car is booked in for 4 wheel alignment to be checked Monday, I'm using a very well trusted local company who've done me well with other complex cars i've owned. So at least I'll know my starting postion.
just to clarify, the SAM was replaced because STAR couldn't communicate with it. Once done there were no fault codes for the suspension system. They gave me the print outs for all the work done. They are a very well respected indie (I just don't want to name names, that unfair incase I'm the idiot)
I've not had a cam position fault code appear again since, so can't do much on that one. My OBD scanner tool isn't the best but good for the basics........ Now I wait for a torrent of abuse !
No abuse from me!
One of the many issues my 230 had was lack of communication from left front SAM, so replaced it.same time I had a corroded fuse box in the same area which caused many gremlins
I invested in an icarsoft MB diagnostic which helped a lot ( kept the repairs for a year below 10k, reckon it saved me 1.5/2k)
Wise move on the alignment and worth checking also if the front and rear tyres are the same brand- we’ve had cases of ‘exciting’ handling caused by tread patterns working against each other- no seriously !!:p
flowrider
SL500 (R230)
No abuse from me!
Good thought on the tyres. I had this issue on my daughters car, when she bought it all 4 tyres were a different brand.
wrightkarl
wrightkarl
Malvern
  • #26
Tyres were one of first thoughts. Its got near new P Zeros all round, that was one of my concerns when the MOT advisory stated excessive wear on NSR inner edge. As has already been said, I don't know when the MOT was done vs the tyres being replaced, either were pretty recent.
peterws1957
Lancashire
Sigh............;)
Yours must have held some sort of record John, despite it's origins. :( I get the impression that there are a disproportionate number of really bad Sl500's around, compared to say SL55's, presumably down to previous poor maintenance on a relatively cheap model and owners being prepared to spend more on an AMG without much complaint.
I think that they've become so cheap people are buying them not realising the running costs then neglecting them when the go wrong. Not a car that accepts neglect.
flowrider
SL500 (R230)
Hopefully more R230's will succumb to poor maintenance resulting in lower surviving numbers and an associated increase in resell values :D
That sounds a bit mean though doesn't it.
wrightkarl
wrightkarl
Malvern
  • #30
Oh well, thats forums for you ;)
Considering the number of new members who take an R230 on as a first dip into Mercedes ownership I think it will be awhile before numbers drop.
flowrider
SL500 (R230)
Could be good news though as it shows demand is still there for the best designed SL, so high demand and low numbers . :)
I think you’ve hit the nail on the head - the problems with that car predated Malcolm and fell under 3 previous owners , 2 of whom did nothing to the car proactively and they’re not accepting of that sort of treatment !
flowrider
SL500 (R230)
When an R230 needs something doing then it's best to get it done else problems can build up.
