My slightly bent rear bumper
Conor
London, UK
Hello,
Back when my rear suspension was leaking, my car dropped down onto pavement/curbing.
At the time I hadn't realised this and later on I proceeded to drive off and nearly pulled the entire bumper off.. lucky for me I was quick on the brakes.
Anyway, on the following pictures you will see the slight damage that was caused. It's not massive and can live with it, but it absolutely bugs me out, and you can be sure I notice it every time I look at the car.
I'm wondering how I could go about fixing that. It basically needs to be pulled in? I wondering is there something I can attach to the rear side and then kind of ratchet tight to pull over in the exposed piece?
What do people think I could do? A totally DIY job is all I have in mind.
index.php
vtaylor78
Northamptonshire.
E350 CDI Coupe C207 2010 \ SLK 250 R172 2011.
Is that bit plastic? You could try a bit of heat, and see if you can manipulate back to correct position.
Yes, I would try a bit of heat (hairdryer) and a bit of bending back.
Jim2
Do you mean that bit beside the exhaust, to the right of it? Yes as Alexanderfoti say's, heat the area and push it gently back...a little further that it need's to go, and it will spring back a bit, so you can judge just when it's aligned again.
umblecumbuz
Wales and Gozo
Heat will probably do the trick, but I think you'll find that, with the mass of the plastic wicking heat away fast, a hairdryer will not be man enough for the job.
Try a heat gun - there will be plenty of heat with that.
vtaylor78
Northamptonshire.
Not Man enough ?? What even a Dyson Supersonic at £529. !! :eek:
Jim2
If you don't mind me asking vtaylor78....what kind of hair are you drying???:shock::shock::shock::shock::D
Jim2
Not me , I use a towel, it’s her indoors :D
Ah... that explains it.!!!! I tend to keep as far away as I can from these appliances used by the Women in my Life, as -I have learned through sometimes painful experience !!!:):):):)
vtaylor78
Northamptonshire.
Very wise Jim .
Chrishazle
Nr Ashford, Kent
Be careful though - a very experienced body shop man heated the oversills of my 968 (which are some kind of plastic). He knew what he was doing, as he did bodywork for top end rally cars, FIA GT1 Nissan Nismo GTR's and their Le Mans LMP1 car! He could not persuade the oversill completely into place as, in his words, he was worried that more heat could damage the paint. The end gap was quite small, so I got some really sticky black mastic, let it cure for 30 minutes then pushed the offending piece into place, it stuck, cleaned off the excess with white spirit, and 6 years later it's still OK.
