davidsl500
- Oct 24, 2004
- Age
- 122
- Location
- Home : Derbyshire at the moment !
- R172 250CDI Gone..!, R129 SL500 Gone...
I had a bit of an issue removing the N10 Combination relay on my R129 500SL – one of those “did I really do that” moments….
So now I need a wiring diagram / cable colours for the relay socket pin connector positions… As I grabbed the relay and pulled the latch all the cables fell out of the socket….grhhh.
I think I have put them back as they came out – but with 3 rows of 7 connectors there are a lot of permutations!
It’s been a bit of a catalogue of errors that I wish I hadn’t started now. The original problem was that the wipers did not work on any position apart from fast speed. I addition they would park anywhere and the wash wipe washed but no wipe. Lights and indicators all worked fine.
The next error was that when I put the connectors back in I did not check all was as before by reinserting the relay - instead I sent it off for a service exchange item via carl at W140. When I plugged the replacement in all hell broke loose. Wipers came on as soon as the ignition was switched on apart from slow wipe where they stopped and the indicators are up the wall.. So it looks like I have a few wires wrong in the socket – or the replacement relay isn’t working as it should (though it came back with a comprehensive test sheet)
So I am a bit stuck now. I did find the cable colour codings on another site but I don’t seem to have all the same colours and their diagram showed 19 cables connected on the 7x3 array and I only have 18!
Help!!
Help!!
