Near Side Rear Tyre Wear
Status
Not open for further replies.
jazza
Merc 200 Avongarde Kompressor :
Any info going arround on what seems to be abnormally high wear on the near side rear tyre. Car has done 14000mls all other tyres are in excellent cond, this one needs changing :? :?
kiwi_bloke
New Zealand
normal?
well im a newbie and i may be wrong (correct me please :) ) but ussualy the back right wheel is ussually the driving wheel in most cars thus resulting in more wear? or it could just simply be something like tirepressures......look into those two ideas
josh
Guy
Manchester
S212 Estate 2010 Brabus D6 350CDI
My 300TD suffered similarly - rear wheel was out of alignment.
A laser alignment tool, and a 2 minute adjustment cost nothing from the guys who were replacing the tyre.
Hope yours is as simple :)
Guy
Manchester
Whoops double post :oops:
piestore
manchester
Tyre wear
hi
sounds like wheel alignment as prevous post says, could be any wheel causing wear on that one. The good news is that MB's are adjustable on all four corner's. Might not sound that good but it is quite unusual. I would recomend full Geo check on MB equipment but it is quite dear about 180 pound ( but very good)
waggers
Bedfordshire
CLK 63 AMG Cabriolet
NSRear...it's due to your driving style...sliding around corners and rounabouts....had the same thing on my old Saab 900 Turbo and that's front wheel drive...nsr bald as a coute in 7000 miles..others were perfect....after I got used to the car and the play factor reduced I managed to then get it up to 12,000 and eventually around 15K..so all depends on how you want to drive it!
Loff
Cumbria
I had a similar problem on a VW Golf after it was lowered. A local Peugeot dealer had 4 wheel alignment equipment and set it up for £40. It was a different car after that !
waggers
Bedfordshire
Main dealer will do the full alignment for £100 incl. Worth doing.
Status
