Need 94 C280 HELP PLEASE!!!!
stargazer474
New Registration
Ohio (U.S.A.)
Hi All ,
I need to know if anyone can help me out here i just bought a 1994 C280 and it has some eletrical tweaks wrong with it ,, the interearer lights and dash lights want to stay on when the car is turned off also the out side lisence plate lights want to stay on even when the car is turned off , , sence i have just bought the car i have just been unhooking the negative battery cable to prevent the battery from being drained ( i just bought a brand new battery for it ) , also the drivers side door buzzer --> the buzzer that is supposed to come on if u leave your keys in the ignition stays buzzing even when the keys are NOT in the ignition, but only when u open the drivers door the keys are not in the ignition and the car is turned off while is stays buzzing ( it is driving me nuts!! )
The headlight switch seems to be messed up also , but i do not know if that switch would have something to do with the lights staying on when the car is turned off or not,, also my SRS light on the dash is staying lit up, i dont know if this is due to the same problem or not ,,
can someone pleaseeeee help meeeeee???????
Thanks a Bunch!!!!
Stargazer474
Parrot of Doom
Manchester
I suggest the door switch that controls the lights may be duff or dirty.
