Luckycharms_74
- Aug 6, 2023
- S class W221 (07 model)
Hi all
I have a 2007 SClass W221 and got an Mekede android unit installed that runs apple car play. The installer only realised when installing that there is no AUX on my car.
He advised to use FM transmitter with an AUX cable input but there is a high pitched whine / hum . I know FM transmitters can give issues but this is quite noticeable and annoying to use.
I’m dropping the car to my local garage for them to look at it and try solve the issue.
I have seen online that you can add an AUX connection but not sure how reliable they are, I suppose anything is better then the current situation
I have ordered a new AUX CABLE & ground loop isolator ( I’m not even sure if this will work)
ZIOCOM Ground Loop Noise Isolator, Noise Filter, Eliminate the Buzzing Noise for Car Audio/Home Stereo System with 3.5mm Audio Cable https://amzn.eu/d/akEOvzs
I have read that it needs grounding due to alternator in the car but I honestly don’t know
I have added pic of the new screen & the centre console which only has Bluetooth for phone . There is also nothing in the glove box
Any help would be much appreciated
