Need help finding cause of leak
poppy
chigwell row essex
300sl1987,range rover p38 2 nissan micras
I have just purchased a R107. I have found that after rain, there is a considerable amount of water in the drivers side foot well. Someone has suggested taking the front air vent below the windscreen off, by removing the three pins inside the bonnet, apparently this will allow the grill to slide out.
The pins do not seem to want to come out:sad:
Has anyone removed this, are there any tips you can give:confused:
Thanks in advance:)
star
Reading
Smart + others :)
you need to push the center of the pin thru and the remove.
P
poppy
chigwell row essex
thanks for that , it is what i was told just to scared to push hard . would you say this is the best way to chech pipes are clear.
star
Reading
Smart + others :)
I'm affraid to say but you might find some rust in there or its the windscreen seal.
P
poppy
chigwell row essex
thank you for your help , i have removed the grill but had no luck in trying to clear the drain pipe . i am now going to get underneath and try clearing it from there . i did not see any signs of rust in there ,but it looks a bit of a larger gap between the windscreen and the chome surround stip on that side. is the windscreen bonded do you know ? it's a shame you are so far from me i would have liked to pop it in to you . is there anyone in the essex area you would recommend for this sort of thing .
www.W140.co.uk&www.r129.co
